After recent update, PoolMath forgets partially entered measurements
jesper
62
Cyprus
Hi,
After a recent update, I'm seeing that I lose partially entered measurements if I change to a different app. This is the iPhone iOS version of PoolMath.
I usually change to a different app, e.g. Chrome browser, to get the water temperature, but doing so causes PoolMath to forget any entered data when I return to PoolMath. PoolMath is back at the overview.
In older version of PoolMath this didn't happen.
More than once, I've forgotten to save, and lost all the measurements I just did - causing me to have to redo them.
Hope we can fix it.
thanks
Jesper
I occasionally lose signal so I usually save after every entry or perform a couple tests then enter and save. By selecting "logs", then selecting the last line of logs you entered, you can add to the same line of data.
On the App store there was a user who rated the App one star because of this exact issue. I cursed and cursed as I couldn't recreate the issue even though I was on the exact same phone running the exact same iOS version. No matter what I did I couldn't get the App to close.
Then I got hit in the head and thought of one difference, and it turned out to be the source. When I was testing I was using a demo version of PoolMath, not the one in the App Store. Downloaded the version from the App store and was able to recreate the crash first time. Don't ask me what occurred but clearly there was an issue with the live version. Downloaded the internal Beta again and again the issue was addressed. We do plan on taking a second look at this issue shortly and it should be fixed in the next update. That said, I'm unsure when the next update is going to be launched due to some personal/work issues of the developer (IE....he's busy as heck at his day job)
Reactions: jesper
Yep, that is my workaround. But I have to remember to save before I change app, otherwise it is gone.
I see Leebo said in the next reply that it is something that can hopefully be fixed. With a bit of luck I’ll remember to save until then.
Awesome thanks
Reactions: Leebo
This is an old thread
